A30016 alarm in Siemens V70 Drive indicates the Load supply is switched off. This means the internal DC bus voltage is too low, suggesting the main AC incoming power has been removed.
Cause: The DC link voltage is too low.
- Switch on the load supply.
- Check the line supply if necessary.
