A7012 fault in siemens sinamics V90 drive
A7012 alarm in siemens sinamics V90 drive indicates Motor temperature model overtemperature. This means the software’s internal calculation of the motor’s heat is approaching the maximum thermal threshold due to high loads.
Cause: The motor temperature model 1/3 identified that the alarm threshold was exceeded.
  • Check the motor load and reduce it if required.
  • Check the motor surrounding temperature.
