A7473 fault in siemens sinamics V90 drive
A7473 alarm in siemens sinamics V90 drive indicates the EPOS Beginning of traversing range was reached. This means the active movement hit the absolute negative boundary of the permissible travel range.
Cause: When traversing, the axis has moved to the traversing range limit.
Remedy: Move away in the positive direction.
