A7474 fault in siemens sinamics V90 drive
A7474 alarm in siemens sinamics V90 drive indicates the EPOS End of traversing range was reached. This means the active movement hit the absolute positive boundary of the permissible travel range.
Cause: When traversing, the axis has moved to the traversing range limit.
Remedy: Move away in the negative direction.
