AL045 Wrong setting of E-gear ratio fault in Delta ASDA-A2 servo drive
Cause: Setting of E-gear ratio is wrong when power on the servo drive.
  • Check if the setting of E-gear ratio is within the range (1/50~25600).
  • Modify the range of E-gear ratio and cycle power on the servo drive.
