Conn Lost fault in WEG CFW701 Drive indicates an HMI Communication Failure. This means the keypad has lost connection with the control board, usually due to a bad cable contact or electrical noise.
A bad contact in the HMI cable, or electrical noise in the installation, can cause a failure in the communication between the HMI and the control board. In such cases, the operation through the HMI becomes impossible.
Inspect and clean the HMI cable connections. Minimize electrical noise in the installation by rerouting cables or adding shielding.
