A Capacitance Ground Fault in WEG CFW701 Drive indicates a parasitic current leakage. This means extremely long motor cables are creating a high capacitance to ground, which trips the ground fault detection.
Very long motor cables, with more than 100 m (328.08 ft), present a high parasitic capacitance to the ground. The circulation of a leakage current through this capacitance may cause the activation of the ground fault circuit, and consequently an F0074 trip immediately after the inverter enabling.
Reduce the switching frequency set in parameter P0297.
