F0799 fault in WEG CFW701 Drive indicates a High Level of the External PID 2 Process Variable. This means the second external PID feedback sensor remained above the safe threshold, triggering a system fault.
Parameter P1095 is programmed in 2 and the External PID controller 2 feedback value is remaining above the value programmed in P1098 for the time programmed in P1099.
Verify that the process pressure, level, or variables are within expected system parameters. Check the sensor output and parameter values for P1095, P1098, and P1099.
