Coulomb to EMU of Charge Converter
Convert Coulombs (C) to EMU of Charge (Electromagnetic Units) instantly. Includes the C to EMU conversion formula, a quick reference table, and charge unit definitions.
0 EMU
How to Convert Coulombs to EMU of Charge
Converting Coulombs (C) to EMU of Charge (Electromagnetic Units) is a simple calculation used primarily in physics and electrical research. The EMU of Charge is part of the CGS (centimeter-gram-second) system, whereas the Coulomb is the standard unit in the SI (International System).
The Conversion Formula
Since 1 EMU of charge is equal to 10 Coulombs, to convert from Coulombs to EMU, you divide the charge by 10:
EMU = C / 10
Coulomb to EMU Conversion Table
Use the table below for quick reference for common electric charge conversions.
Coulombs (C)EMU of Charge
1 C0.1 EMU
5 C0.5 EMU
10 C1 EMU
50 C5 EMU
100 C10 EMU
1,000 C100 EMU
Contextual Information
What is a Coulomb?
The Coulomb is the SI unit of electric charge. It represents the amount of charge transported by a constant current of one ampere in one second. It is the most common unit used by engineers and students worldwide.
What is an EMU of Charge?
The EMU of Charge, also known as the Abcoulomb or biot, is the unit of charge in the electromagnetic system of units. It is defined as the charge that passes a point in one second when a current of one abampere flows. One EMU is exactly ten times larger than one Coulomb.
Why Convert Between These Units?
While the SI system (Coulombs) is the modern standard, many classical physics papers and specific fields of electromagnetism still use the CGS-EMU system. Knowing how to switch between them is vital for accurately interpreting scientific data and historical formulas.
