Digitax HD M751 Base Drive Fault Codes (2026) – Troubleshooting guide for the Nidec Digitax HD M751 servo drive. Learn to interpret mnemonic trip codes, troubleshoot encoder errors, and use Connect software for diagnostics.
The Nidec Control Techniques Digitax HD M751 is a high-performance “Base” servo drive designed for centralized motion control systems. With integrated dual Ethernet ports and high peak torque capabilities, it is the cornerstone of high-speed packaging, pick-and-place, and CNC applications. When the M751 detects a fault, it halts the servo motor and displays a mnemonic trip code—an abbreviated English string such as OI.AC (Overcurrent) or Enc1 (Encoder 1 Fault).
This 2026 guide provides the diagnostic framework to help you interpret these codes, manage the drive’s SI-option slots, and resolve trips to maintain high-precision motion timing.
Digitax HD M751 Fault Codes Reference Table
Below is the reference list of faults for the Digitax HD M751. Because this is a servo drive, many trips are related to position feedback and current loop stability. Please locate the code appearing on your drive’s display.
| Fault Code and Meaning | Cause and Remedy |
| 217 App Menu Changed Customization table for an application module has changed | Cause: The App Menu Changed trip indicates that the customization table for an application menu has changed. The menu that has been changed can be identified by the sub-trip number. If more than one menu has changed the lowest menu has priority. Drive user parameters must be saved to prevent this trip on the next power-up. Remedy:
| 11 Autotune 1 Position feedback did not change or required speed could not be reached | Cause: The drive has tripped during an autotune. The cause of the trip can be identified from the sub-trip number (e.g., motor did not reach required speed, commutation signal not found, etc.). Remedy:
| 12 Autotune 2 Position feedback direction incorrect | Cause: The drive has tripped during a rotating autotune. The position feedback direction is incorrect when position feedback is being used, or a SINCOS encoder comms position is rotating in the opposite direction to the sine wave. Remedy:
| 13 Autotune 3 Measured inertia has exceeded the parameter range or commutation signals changed in wrong direction | Cause: The drive has tripped during a rotating autotune or mechanical load measurement test. Measured inertia may have exceeded parameter range, or commutation signals changed in the wrong direction. Remedy:
| 14 Autotune 4 Drive encoder U commutation signal fail | Cause: A position feedback device with commutation signals is being used and the U commutation signal did not change during a rotating autotune. Remedy:
| 15 Autotune 5 Drive encoder V commutation signal fail | Cause: A position feedback device with commutation signals is being used and the V commutation signal did not change during a rotating autotune. Remedy:
| 16 Autotune 6 Drive encoder W commutation signal fail | Cause: A position feedback device with commutation signals is being used and the W commutation signal did not change during a rotating autotune. Remedy:
| 17 Autotune 7 Motor number of poles / position feedback resolution set incorrectly | Cause: An Autotune 7 trip is initiated during a rotating autotune, if the motor poles or the position feedback resolution have been set up incorrectly where position feedback is being used. Remedy:
| 18 Autotune Stopped Autotune test stopped before completion | Cause: The drive was prevented from completing an autotune test, because either the drive enable or the drive run were removed. Remedy:
| 19 Brake R Too Hot Braking resistor overload timed out (I2t) | Cause: The Brake R Too Hot indicates that braking resistor overload has timed out. The Brake R Too Hot trip is initiated when Braking Resistor Thermal Accumulator (10.039) reaches 100 %. Remedy:
| 99 CAM Advanced motion controller CAM failure | Cause: The CAM trip indicates that the advanced motion controller CAM has detected a problem. Causes include: Start Index > Cam Size, CAM Index change > 2 in one sample, or rate of change at segment boundary exceeded maximum. Remedy:
| 185 Card Access SD Card Write fail | Cause: The drive was unable to access the SD Card. If a parameter file is transferred to the drive and this trip occurs during the transfer, the parameters are not saved to non-volatile memory. Remedy:
| 177 Card Boot The Menu 0 parameter modification cannot be saved to the SD Card | Cause: A write to a Menu 0 parameter has been initiated via the keypad by exiting edit mode and Pr 11.042 is set for auto or boot mode, but the necessary boot file has not been created on the SD Card. Remedy:
| 178 Card Busy SD Card cannot be accessed as it is being accessed by an option module | Cause: An attempt has been made to access a file on SD Card, but the SD Card is already being accessed by an Option Module. No data is transferred. Remedy:
| 188 Card Compare SD Card file/data is different to the one in the drive | Cause: A compare has been carried out between a file on the SD Card and the drive. A Card Compare trip is initiated if the parameters on the SD Card are different to the drive. Remedy:
| 179 Card Data Exists SD Card data location already contains data | Cause: An attempt has been made to store data on an SD Card in a data block which already contains data. No data is transferred. Remedy:
| 187 Card Drive Mode SD Card parameter set not compatible with current drive mode | Cause: Produced during a compare if the drive mode in the data block on the SD Card is different from the current drive mode. Also produced if transferring parameters from SD Card when the operating mode in the data block is outside the allowed range. Remedy:
| 182 Card Error SD Card data structure error | Cause: An attempt has been made to access an SD Card but an error has been detected in the data structure on the card (e.g. required folder not present, file corrupted). Remedy:
| 184 Card Full SD Card full | Cause: An attempt has been made to create a data block on an SD Card, but there is not enough space left on the card. Remedy:
| 183 Card No Data SD Card data not found | Cause: An attempt has been made to access non-existent file or block on an SD Card. No data is transferred. Remedy:
| 180 Card Option SD Card trip; option modules installed are different between source drive and destination drive | Cause: Parameter data or default difference data is being transferred from an SD Card to the drive, but the option module categories are different between source and destination drives. This acts as a warning. Remedy:
| 175 Card Product SD Card data blocks are not compatible with the drive derivative | Cause: If Drive Derivative (11.028) or Product Type (11.063) are different between the source and target drives then this trip is initiated either at power-up or when the card is accessed. Remedy:
| 186 Card Rating SD Card Trip; The voltage and / or current rating of the source and destination drives are different | Cause: Parameter data is being transferred from an SD Card to the drive, but the current and / or voltage ratings are different between source and destination drives. Remedy:
| 181 Card Read Only SD Card has the Read Only bit set | Cause: An attempt has been made to modify a read-only SD Card or a read-only data block. Remedy:
| 174 Card Slot SD Card Trip; Option module application program transfer has failed | Cause: Initiated if the transfer of an option module application program to or from an application module failed because the option module does not respond correctly. Remedy:
| 35 Control Word Trip initiated from the Control Word (06.042) | Cause: The Control Word trip is initiated by setting bit 12 on the control word in Pr 06.042 when the control word is enabled (Pr 06.043 = On). Remedy:
| 225 Current Offset Current feedback offset error | Cause: The current feedback offset is too large to be trimmed correctly. The sub-trip relates to the output phase for which the offset error has been detected (1=U, 2=V, 3=W). Remedy:
| 97 Data Changing Drive parameters are being changed | Cause: A user action or a file system write is active that is changing the drive parameters and the drive has been commanded to enable. This includes loading defaults, changing drive mode, or transferring data from SD card. Remedy:
| 247 Derivative identification error | Cause: There is a problem with the identifier associated with derivative image which customizes the drive. Sub-trips indicate: Image erased, Identifier out of range, or Image changed. Remedy:
| 248 Derivative Image error | Cause: An error has been detected in the derivative image. Sub-trip numbers indicate specific option module slot conflicts or missing modules required by the image. Remedy:
| 199 Destination parameters write conflict | Cause: Destination parameters of two or more functions (Menus 3, 7, 8, 9, 12 or 14) within the drive are writing to the same parameter. Remedy:
| 224 Power stage recognition: Unrecognized drive size | Cause: The control PCB has not recognized the drive size of the power circuit to which it is connected. Remedy:
| 31 EEPROM Fail (Default parameters loaded) | Cause: Default parameters have been loaded. Possible causes include: Internal parameter database version changed, CRC failure, Mode restored from non-volatile memory outside allowed range, Hardware changes (I/O, Power stage), or EEPROM Checksum failure. Remedy:
| 189 Encoder 1: Drive position feedback interface power supply overload | Cause: The drive encoder power supply has been overloaded (Terminals 13 & 14). Maximum current exceeded (200 mA @ 15V or 300 mA @ 8V/5V). Remedy:
| 190 Encoder 2: Drive encoder (Feedback) wire break | Cause: The drive has detected a wire break on the 15 way D-type connector. Sub-trips indicate specific input or channel (A, B, Z) failures. Remedy:
| 191 Encoder 3: Phase offset incorrect while running | Cause: Incorrect UVW phase angle (RFC-S mode) or SINCOS phase error detected while running. Remedy:
| 192 Encoder 4: Feedback device comms failure | Cause: Encoder communications timed out or message transfer time is too long. Can be caused by wire break in comms channel. Remedy:
| 193 Encoder 5: Checksum or CRC error | Cause: Checksum or CRC error, or the SSI encoder is not ready. Can also indicate a wire break to a communications based encoder. Remedy:
| 194 Encoder 6: Encoder has indicated an error | Cause: The encoder has indicated an error or the power supply has failed to an SSI encoder. Can also indicate a wire break to an SSI encoder. Remedy:
| 195 Encoder 7: Set-up parameters changed | Cause: The set-up parameters for position feedback device have changed. Remedy:
| 196 Encoder 8: Position feedback interface timed out | Cause: Position feedback interface communications time exceeds 250 µs. Remedy:
| 197 Encoder 9: Invalid feedback source selection | Cause: Position feedback source selected in Pr 03.026 (or Pr 21.021) is not valid (option module slot does not have a feedback option module installed). Remedy:
| 162 Encoder 12: Encoder type not recognized | Cause: The drive is communicating with the encoder but the encoder type is not recognized during auto-configuration. Remedy:
| 163 Encoder 13: Data read out of range | Cause: Data read from the encoder is out of range during auto-configuration. Sub-trips indicate: Rotary lines error, comms pitch error, line pitch error, rotary turns bits error, comms bits error, or calculation/line delay time too long. Remedy:
| 6 External Trip initiated | Cause: An External Trip has occurred. Can be initiated by Safe Torque Off inputs or by writing a value of 6 in Pr 10.038. Remedy:
| HF01 Data processing error: CPU address error | Cause: A CPU address error has occurred. The control PCB on the drive has failed. Remedy:
| HF02 Data processing error: DMAC address error | Cause: A DMAC address error has occurred. The control PCB on the drive has failed. Remedy:
| HF03 Data processing error: Illegal instruction | Cause: An illegal instruction has occurred. The control PCB on the drive has failed. Remedy:
| HF04 Data processing error: Illegal slot instruction | Cause: An illegal slot instruction has occurred. The control PCB on the drive has failed. Remedy:
| HF05 Data processing error: Undefined exception | Cause: An undefined exception error has occurred. The control PCB on the drive has failed. Remedy:
| HF06 Data processing error: Reserved exception | Cause: A reserved exception error has occurred. The control PCB on the drive has failed. Remedy:
| HF07 Data processing error: Watchdog failure | Cause: A watchdog failure has occurred. The control PCB on the drive has failed. Remedy:
| HF08 Data processing error: CPU Interrupt crash | Cause: A CPU interrupt crash has occurred. The control PCB on the drive has failed. Remedy:
| HF09 Data processing error: Free store overflow | Cause: The HF09 trip indicates that a free store overflow has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF10 Data processing error: Parameter routing system error | Cause: The HF10 trip indicates that a Parameter routing system error has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF11 Data processing error: Access to EEPROM failed | Cause: The HF11 trip indicates that access to the drive EEPROM has failed. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF12 Data processing error: Main program stack overflow | Cause: The HF12 trip indicates that the main program stack overflow has occurred. The stack can be identified by the sub-trip number (1: Background, 2: Timed, 3: Main system). Remedy:
| HF13 Data processing error: Firmware incompatible with hardware | Cause: The HF13 trip indicates that the drive firmware is not compatible with the hardware. Remedy:
| HF14 Data processing error: CPU register bank error | Cause: The HF14 trip indicates that a CPU register bank error has occurred. This trip indicates that the control PCB on the drive has failed. Remedy:
| HF15 Data processing error: CPU divide error | Cause: The HF15 trip indicates that a CPU divide error has occurred. Remedy:
| HF16 Data processing error: RTOS error | Cause: The HF16 trip indicates that a RTOS error has occurred. Remedy:
| HF17 Data processing error: Clock supplied to the control board is out of specification | Cause: The HF17 trip indicates that the clock supplied to the control board logic is out of specification. Remedy:
| HF18 Data processing error: Internal flash memory has failed | Cause: The internal flash memory has failed when writing option module parameter data. Sub-trips: 1 (Programming error), 2 (Erase setup menu failed), 3 (Erase application menu failed). Remedy:
| HF19 Data processing error: CRC check on the firmware has failed | Cause: The CRC check on the drive firmware has failed. Remedy:
| HF20 Data processing error: ASIC is not compatible with the hardware | Cause: The ASIC version is not compatible with the drive firmware. Remedy:
| HF23 to HF25 Hardware fault | Cause: General hardware failure. Remedy:
| Inductance Trip 8 Inductance measurement out of range or motor saturation not detected | Cause: Occurs in RFC-S mode when motor inductances are not suitable or saturation characteristic cannot be measured. Remedy:
| I/O Overload Trip 26 Digital output overload | Cause: Total current drawn from 24 V user supply or from the digital output has exceeded the limit (>100 mA). Remedy:
| Keypad Mode Trip 34 Keypad has been removed when the drive is receiving the speed reference from the keypad | Cause: Drive is in keypad mode [Reference Selector = 4 or 6] and the keypad has been removed or disconnected. Remedy:
| Motor Too Hot Trip 20 Output current overload timed out (I²t) | Cause: Motor thermal overload based on Rated Current and Motor Thermal Time Constant. Drive trips when thermal accumulator reaches 100%. Remedy:
| Name Plate Trip 176 Electronic nameplate transfer has failed | Cause: Electronic name plate transfer between drive and motor failed. Sub-trips: 1 (Not enough memory), 2 (Communication failed), 3 (Transfer failed), 4 (Checksum failed). Remedy:
| OHt Brake Trip 101 Braking IGBT over-temperature | Cause: Braking IGBT over-temperature detected based on software thermal model. Remedy:
| OHt Control Trip 23 Control stage over temperature | Cause: Control stage over-temperature detected via thermistors on Control board or I/O board. Remedy:
| OHt dc bus Trip 27 DC bus over temperature | Cause: DC bus component over temperature based on software thermal model. Causes include high output current or DC bus ripple. Remedy:
| OHt Inverter Trip 21 Inverter over temperature based on thermal model | Cause: IGBT junction over-temperature detected based on software thermal model. Remedy:
| OHt Power (22) Power stage over temperature | Cause: A power stage over-temperature has been detected. The thermistor location indicating the over-temperature is identified by the sub-trip. Remedy:
| OI ac (3) Instantaneous output over current detected | Cause: The instantaneous drive output current has exceeded VM_DRIVE_CURRENT[MAX]. This trip cannot be reset until 10s after the trip was initiated. Remedy:
| OI Brake (4) Braking IGBT over current detected | Cause: Short circuit protection for the braking IGBT has been activated. Remedy:
| OI dc (109) Power module over current detected from IGBT on state voltage monitoring | Cause: The short circuit protection for the drive output stage has been activated. This trip cannot be reset until 10s after the trip was initiated. Remedy:
| OI Snubber (92) Snubber over-current detected | Cause: An over-current condition has been detected in the rectifier snubber circuit. Remedy:
| Option Disable (215) Option module does not acknowledge during drive mode changeover | Cause: The option module did not acknowledge to the drive that communications with the drive has been stopped during the drive mode changeover within the allocated time. Remedy:
| Out Phase Loss (98) Output phase loss detected | Cause: Phase loss has been detected at the drive output. Remedy:
| Over Speed (7) Motor speed has exceeded the over speed threshold | Cause: The Output Frequency or Speed Feedback exceeds the threshold set in Over Speed Threshold. Remedy:
| Over Volts (2) DC bus voltage has exceeded the peak level or maximum continuous level | Cause: The DC bus voltage has exceeded the VM_DC_VOLTAGE[MAX] limits. Remedy:
| Phase Loss (32) Supply phase loss | Cause: Input phase loss or large supply imbalance detected from the supply or DC bus ripple monitoring. Remedy:
| Phasing Error (198) RFC-S mode phasing failure due to incorrect phase angle | Cause: The phase offset angle in Pr 03.025 is incorrect, position feedback is being used and the drive is unable to control the motor correctly. Remedy:
| Power Comms (90) Communication has been lost / errors detected between power, control and rectifier | Cause: A communications problem within the power system of the drive. Remedy:
| Power Data (220) Power system configuration data error | Cause: There is an error in the configuration data stored in the power system. Remedy:
| Power Down Save (37) Power down save error | Cause: An error has been detected in the power down save parameters saved in non-volatile memory. Remedy:
| PSU (5) Internal power supply fault | Cause: One or more internal power supply rails are outside limits or overloaded. Remedy:
| PSU 24V (9) 24V internal power supply overload | Cause: The total user load of the drive and option modules has exceeded the internal 24 V power supply limit. Remedy:
| Resistance (33) Measured resistance has exceeded the parameter range | Cause: Either the value being used for motor stator resistance is too high or an attempt to do a test involving measuring motor stator resistance has failed. Remedy:
| 216 Slot App Menu | Cause: The Slot App Menu trip indicates that more than one option slot has requested to customize the application menus 18, 19 and 20. The sub-trip number indicates which option slot has been allowed to customize the menus. Remedy:
| 204, 209, 214 SlotX Different | Cause: The SlotX Different trip indicates that the option module in option slot X on the drive is a different type to that installed when parameters were last saved on the drive. Remedy:
| 202, 207, 212 SlotX Error | Cause: The SlotX Error trip indicates that the option module in option slot X on the drive has detected an error. The reason for the error can be identified by the sub-trip number. Remedy:
| 200, 205, 210 SlotX HF | Cause: The SlotX HF trip indicates that the option module in option slot X cannot operate. The possible causes of the trip can be identified by the sub-trip number (e.g., module category not identified, tables corrupt, etc.). Remedy:
| 203, 208, 213 SlotX Not Fitted | Cause: The SlotX Not Fitted trip indicates that the option module in option slot X on the drive has been removed since the last power up. Remedy:
| 201, 206, 211 SlotX Watchdog | Cause: The SlotX Watchdog trip indicates that the option module installed in Slot X has started the option watchdog function and then failed to service the watchdog correctly. Remedy:
| 226 Soft Start | Cause: The Soft Start trip indicates that the soft start relay in the drive failed to close or the soft start monitoring circuit has failed. Remedy:
| 221 Stored HF | Cause: The Stored HF trip indicates that a hardware trip (HF01 – HF20) has occurred and the drive has been power cycled. The sub-trip number identifies the HF trip i.e. stored HF.17. Remedy:
| 227 Sub-array RAM | Cause: The Sub-array RAM indicates that an option module, derivative image or user program image has requested more parameter RAM than is allowed. The failure is detailed by the sub-trip number. Remedy:
| 218 Temp Feedback | Cause: The Temp Feedback trip indicates that an internal thermistor has failed. The thermistor location can be identified by the sub-trip number. Remedy:
| 10 Th Brake Res | Cause: Brake resistor over temperature. The Th Brake Res is initiated if hardware based braking resistor thermal monitoring is connected and the resistor overheats. Remedy:
| 25 Th Short Circuit | Cause: The Th Short Circuit trip indicates that the motor thermistor connected to the drive is short circuit or low impedance i.e. < 50 Ω. Remedy:
| 24 Thermistor | Cause: The Thermistor trip indicates that the motor thermistor connected to the drive has indicated a motor over temperature. Remedy:
| 110 Undefined | Cause: The Undefined trip indicates that the power system has generated but did not identify the trip from the power system. The cause of the trip is unknown. Remedy:
| 249 User Program | Cause: The User Program trip indicates that an error has been detected in the onboard user program image. The reason for the trip can be identified by the sub-trip number (e.g., Divide by zero, Undefined trip, Parameter access errors). Remedy:
| 96 User Prog Trip | Cause: Trip generated by an onboard user program. This trip can be initiated from within an onboard user program using a function call. Remedy:
| 36 User Save | Cause: User Save error / not completed. The trip indicates an error detected in the user save parameters saved in non-volatile memory (e.g., power removed during save). Remedy:
| 40-89, 112-159 User Trip | Cause: User generated trip. These trips are not generated by the drive and are to be used by the user to trip the drive through an application program. Remedy:
| 30 Watchdog | Cause: Control word watchdog has timed out. The Watchdog trip indicates that the control word has been enabled and has timed out. Remedy:
| Error 1 Insufficient Drive Memory | Cause: There is not enough drive memory requested by all the option modules. Remedy: Power down drive and remove some of the option modules until the message disappears. |
| Error 2 Option Module Reset Failure | Cause: At least one option module did not acknowledge the reset request. Remedy: Power cycle drive. |
| Error 3 Flash Erase Failed | Cause: The boot loader failed to erase the processor flash. Remedy: Power cycle drive and try again. If problem persists, return drive. |
| Error 4 Flash Program Failed | Cause: The boot loader failed to program the processor flash. Remedy: Power cycle drive and try again. If problem persists, return drive. |
| Error 5 Option Module Init Failed | Cause: One option module did not initialize correctly. Option module did not set Ready to Run flag. Remedy: Remove faulty option module. |
| Brake Resistor Brake resistor overload | Cause: Braking Resistor Thermal Accumulator (10.039) in the drive has reached 75.0 % of the value at which the drive will trip. Remedy: Check braking cycle and load. (Alarm indicates impending trip). |
| Motor Overload Motor protection warning | Cause: Motor Protection Accumulator (04.019) in the drive has reached 75.0 % of the value at which the drive will trip and the load on the drive is >100 %. Remedy: Check motor load and duty cycle. |
| Ind Overload Regen inductor overload | Cause: Inductor Protection Accumulator (04.019) in the drive has reached 75.0 % of the value at which the drive will trip and the load on the drive is >100 %. Remedy: Reduce load on the drive. |
| Drive Overload Drive over temperature | Cause: Percentage Of Drive Thermal Trip Level (07.036) in the drive is greater than 90 %. Remedy: Check drive cooling and ambient temperature. |
| Auto Tune Autotune in progress | Cause: The autotune procedure has been initialized and an autotune is in progress. Remedy: Wait for autotune to complete. |
| Limit Switch Limit switch active | Cause: Indicates that a limit switch is active and that is causing the motor to be stopped. Remedy: Check system limit switches. |
| Inhibit Drive Inhibited | Cause: The Safe Torque Off signal is not applied to Safe Torque Off terminals or Pr 06.015 is set to 0. Remedy: Apply STO signal or check parameters to enable. (Output Stage: Disabled). |
| Ready Drive Ready | Cause: The drive enable is active, but the drive inverter is not active because the final drive run is not active. Remedy: Activate run command. (Output Stage: Disabled). |
| Stop Stopped | Cause: The drive is stopped / holding zero speed. Remedy: Normal operation. (Output Stage: Enabled). |
| Run Running | Cause: The drive is active and running. Remedy: Normal operation. (Output Stage: Enabled). |
| Scan Regen Synchronization | Cause: The drive is enabled in Regen mode and is trying to synchronize to the supply. Remedy: Wait for synchronization. (Output Stage: Enabled). |
| Supply Loss Supply Loss Detected | Cause: Supply loss condition has been detected. Remedy: Check input power supply. (Output Stage: Enabled). |
| Deceleration Decelerating | Cause: The motor is being decelerated to zero speed / frequency because the final drive run has been deactivated. Remedy: Normal operation. (Output Stage: Enabled). |
| dc injection DC Injection Braking | Cause: The drive is applying dc injection braking. Remedy: Normal operation. (Output Stage: Enabled). |
| Position Position Control Active | Cause: Positioning / position control is active during an orientation stop. Remedy: Normal operation. (Output Stage: Enabled). |
| Trip Drive Tripped | Cause: The drive has tripped and no longer controlling the motor. Remedy: Check the trip code appearing in the lower display. (Output Stage: Disabled). |
| Active Regen Active | Cause: The regen unit is enabled and synchronized to the supply. Remedy: Normal operation. (Output Stage: Enabled). |
| Under Voltage Under Voltage State | Cause: The drive is in the under voltage state either in low voltage or high voltage mode. Remedy: Check DC bus voltage and supply. (Output Stage: Disabled). |
| Heat Pre-heat Active | Cause: The motor pre-heat function is active. Remedy: Normal operation. (Output Stage: Enabled). |
| Phasing Phasing Test | Cause: The drive is performing a ‘phasing test on enable’. Remedy: Wait for test completion. (Output Stage: Enabled). |
Servo Diagnostic Note: Digitax HD drives utilize Sub-trip strings (Parameter 10.070). Because the M751 is a compact drive with high integration, the sub-trip string is essential for identifying which specific internal power stage or encoder channel triggered the event.
How to Read M751 Faults via Connect Software
In 2026, the complexity of high-speed servo loops makes the Control Techniques Connect software the primary tool for deep-dive diagnostics on the Digitax HD M751. Since the M751 features onboard Ethernet, you can connect directly over the network.
- Onboard Ethernet Diagnostics: You can access the drive’s trip log and internal monitors (torque, speed, position) via Modbus TCP or EtherNet/IP. This allow for remote troubleshooting without opening the electrical cabinet.
- High-Speed Data Logger: The M751 features a high-speed “freeze-frame” logger. When a trip occurs, the drive captures motion-critical data with microsecond precision. This is vital for diagnosing dEv (Speed Deviation) or Enc (Encoder) faults that only happen at peak velocities.
- Trip History (Menu 10): The drive stores the last 10 trips in Parameters 10.020 to 10.029. With “Connect,” you can see the precise motor status and current levels at the exact moment the drive entered a fault state.
- SI-Option Slot: The M751 has one SI-option slot for additional feedback or I/O. If a trip occurs related to an option card, the sub-trip string will identify “Slot 1” as the source.
Q: What is the difference between a Trip and a Warning on the M751?
A: A Trip (Solid code) is a protective shutdown that stops the motor immediately to prevent hardware damage or runaway conditions. A Warning (Flashing code) indicates the drive is nearing a limit—such as Hot (Heatsink temperature) or O.Ld (Load Warning)—allowing the controller to reduce the cycle rate before a hard trip occurs.
Q: How do I reset a Digitax HD M751 fault?
A: Once the root cause (such as a mechanical jam or cable issue) is resolved, you can reset the drive via:
- Pressing the Red STOP/RESET button on the drive keypad (if installed).
- Cycling the Main Power (Ensure the display goes completely dark before reapplying power).
- Sending a reset command via the Ethernet network (Modbus TCP/EtherNet/IP).
- Toggling a Digital Input assigned to the “Reset” function (Parameter 10.033).
Q: What does “inh” (Inhibit) mean?
A: “inh” is a status code, not a fault. It means the Safe Torque Off (STO) terminals are not receiving a 24V signal. The drive is healthy but is being prevented from running by an external safety controller or E-stop button.
Q: Why am I getting “Enc1” trips?
A: Enc1 indicates a fault with the primary encoder. In servo systems, this is often caused by electrical noise on the encoder cable, a loose connector at the motor, or a failure of the encoder itself. Ensure you are using high-quality shielded cables grounded at the drive end.
Q: Where is the trip history stored?
A: The trip history is stored in non-volatile memory in Menu 10. Parameter 10.020 always contains the most recent trip data, and this log is preserved even when the drive is powered down.
