E.dOH fault in KEB COMBIVERT F5 Drive
E.dOH fault in KEB COMBIVERT F5 Drive indicates a Motor Overheat. This means the external PTC temperature sensor has tripped, signaling that the motor is running dangerously hot.
If a motor PTC temperature sensor, relay, or KTY (special hardware required) is connected to terminals T1, T2 and the motor overheat function US.33 EdOH Function = On, then the relay opens when PTC resistance exceeds 1650 Ohms.
Excessive motor heating causes may include:
  • Excessive current.
  • Incorrect encoder settings.
  • High mechanical load/friction.
  • Insufficient motor cooling.
  • Verify correct motor data.
  • Verify correct encoder settings including:
    • LF.27: Encoder Pulse Number
    • LF.28: Swap Encoder Channels (A/B setting)
    • LF.77: Encoder Pole position for PM Synchronous Motors.
  • Check for high mechanical load/issues (friction).
  • Inspect and ensure sufficient motor cooling.
