E.OH2 fault in KEB COMBIVERT F5 Drive
E.OH2 fault in KEB COMBIVERT F5 Drive indicates a Motor Protection error. This means the electronic motor overload protection was activated because the RMS motor current exceeded safe parameters.
Excessive RMS motor current according to the LF.08 Electric Motor Protection overload curve, or if the LF09 Peak Motor Current Factor is exceeded for more than 3 seconds for PM Synchronous Motors.
  • For induction motors, the baseline current for Electric Motor Protection corresponds to LM09 Electric Motor Overload Current.
  • For PM Synchronous Motors, the baseline current corresponds to LF.12 Motor Current.
  • Verify motor data, specifically the motor rated speed and frequency relationship for PM Synchronous Motors (see Section 5.6.2).
  • Verify correct encoder settings including:
    • LF.27: Encoder Pulse Number
    • LF.28: Swap Encoder Channels (A/B setting)
    • LF.77: Encoder Pole position for PM Synchronous Motors. Relearn Encoder Pole Position as needed (see Section 5.11).
  • Check for high mechanical load/issues (friction).
