F0048 fault in WEG CFW500 Drive
F0048 fault in WEG CFW500 Drive indicates an Overload on the IGBTs. This means the internal power transistors experienced sustained excessive current and tripped to prevent thermal damage.
  • Inverter output overcurrent is greater than 2xInom.
Check active load levels to lower current spikes. Inspect system sizing.
