F0033 fault in WEG CFW500 Drive indicates a Self-tuning Fault. This means the inverter failed to accurately measure the motor’s stator resistance during the automatic setup procedure.
- Stator resistance value in parameter P0409 does not comply with the inverter power rating.
- Motor connection error.
- Connected motor power rating is too low or too high in relation to the inverter capacity.
Turn off the power supply and inspect all connections at the motor terminal box. Verify if stator resistance parameter P0409 and motor power ratings are configured correctly.
