F0048 fault in WEG CFW701 Drive
F0048 fault in WEG CFW701 Drive indicates an IGBT Overload Fault. This means the internal power transistors experienced sustained excessive current and tripped to prevent thermal damage.
  • The inverter output current is too high.
Analyze load conditions to prevent high current output. Check drive/inverter capacity matching.
