F0153 fault in WEG CFW701 Drive
F0153 fault in WEG CFW701 Drive indicates Internal Air Overtemperature. This means the ambient air inside the drive exceeded critical limits, triggering a protective shutdown.
  • High surrounding air temperature (>50 °C (122 °F)) and high output current.
  • Defective internal cooling fan (if existent).
Check and clear air grilles or replace defective fans. Reduce room/enclosure temperature.
