F0238 fault in WEG CFW500 Drive
F0238 fault in WEG CFW500 Drive indicates the Profibus DP Interface is in Clear Mode. This means the Profibus master commanded a safe clear state, causing the drive to execute a fault response.
  • The network master status is not in run mode.
Verify the network master status, making sure it is in execution mode (Run).
