F0239 fault in WEG CFW500 Drive
F0239 fault in WEG CFW500 Drive indicates the Profibus DP Interface is Offline. This means the physical Profibus network link completely dropped, triggering a communication fault.
  • The network master is not configured or operating normally.
  • Short circuit or loose contact on the communication cables.
  • Cables are misconnected or inverted.
  • Improperly placed termination resistors (should only be installed at the physical ends of the main bus).
  • Profibus DP network cable routing or grounding is inadequate.
Check the PLC state. Check general cable routing, connection shield lines, and grounding terminals. Refer to the Profibus DP communication manual.
