F0240 fault in WEG CFW500 Drive
F0240 fault in WEG CFW500 Drive indicates a Profibus DP Module Access Fault. This means the drive’s main processor completely lost access to the Profibus module, causing a fault trip.
  • The Profibus DP module is not seated properly in the slot.
  • Hardware errors due to improper handling or installation of the accessory module.
Verify Profibus module mounting in slot. Replace communication module if handling errors damaged the pins.
