F0700 fault in WEG CFW500 Drive indicates a Remote HMI Communication Fault. This means the serial data link to the keypad was broken while the drive was actively relying on it for commands.
- HMI cable is disconnected.
- Communication interface with the HMI is incorrectly configured in parameter P0312.
Check parameter P0312 to verify that the HMI communication interface is configured correctly. Reconnect or replace the HMI serial cable.
