F0761 fault in WEG CFW500 Drive indicates a Low Level of the Main PID Process Variable. This means the drive switched off the motor because the process feedback sensor remained below the safe threshold for too long.
- Parameter P1030 is programmed for 2, and the process variable value has dropped below the threshold in P1031 for the time programmed in P1032.
Verify the process feedback sensor. Adjust parameters P1031 (threshold) and P1032 (delay time) if necessary.
