F0763 fault in WEG CFW500 Drive indicates a High Level of the Main PID Process Variable. This means the drive switched off the motor because the process feedback sensor remained above the safe threshold for too long.
- Parameter P1030 is programmed for 2, and the process variable value has exceeded the threshold in P1033 for the time programmed in P1034.
Check for high limits in the process line (overpressure, high flow, etc.). Verify parameters P1033 and P1034.
