F1103 fault in WEG CFW900 Drive
F1103 fault in WEG CFW900 Drive indicates a Slot A Accessory Connection Error. This means the drive lost physical or electrical communication with the card installed in Slot A.
Loss of communication with the accessory.
  • Above-supported electromagnetic noise.
  • Vibration above supported limits causing connector problems.
  • Corrupted accessory firmware.
Reduce local electromagnetic noise and structural vibrations. Inspect physical terminals and check accessory board firmware state.
