A1104 / F1105 fault in WEG CFW900 Drive
A1104 / F1105 Slot A Temperature Warning / Fault Temperature or overtemperature inside the Slot A accessory is high. fault in WEG CFW900 Drive
These codes indicate a Slot A Temperature anomaly. This means the accessory in Slot A is overheating, likely due to high ambient cabinet temperatures.
  • Temperature around the inverter is close to or above 60 ºC.
Check and improve enclosure ventilation. Inspect cooling fans or auxiliary cabinet cooling systems. Ensure ambient operating temperature is within limits.
