F155 fault in WEG CFW900 Drive
F155 fault in WEG CFW900 Drive indicates a Control Internal Air Overtemperature. This means the control circuit area overheated and the drive tripped to prevent hardware damage.
Control circuit overtemperature fault.
  • High ambient temperature around the inverter (>50 °C) and high output current.
  • Locked or defective fan.
  • Inverter heat sink too dirty.
Check cooling fan, clean heatsink, and reduce ambient/room temperatures if too high.
