F234 fault in WEG CFW900 Drive indicates a Bus Off condition on the CAN interface. This means the CAN network experienced severe data collisions or wire shorts and disconnected itself to protect the network.
Bus off error detected on the CAN interface.
- Verify if there is any short-circuit between the CAN circuit transmission cables.
- Verify if the cables have not been changed or inverted.
- Verify if all the network devices use the same baud rate.
- Verify if termination resistors with the correct values were installed only at the extremes of the main bus.
- Verify if the CAN network was properly installed.
Verify CAN cabling polarity and check for line shorts. Match network node baud rates. Check termination resistor locations. Cycle power to reestablish communications.
