F30021 fault in Siemens V70 Drive
F30021 fault in Siemens V70 Drive indicates a Ground fault. This means electrical current is escaping to the earth ground, usually caused by damaged insulation on the motor cables or inside the motor windings.
Power unit has detected a ground fault.
  • Ground fault in the power cables.
  • Winding fault or ground fault at the motor.
  • Check the power cable connections.
  • Check the motor.
