F30027 fault in Siemens V70 Drive
F30027 fault in Siemens V70 Drive indicates a Precharging DC link time monitoring failure. This means the internal DC bus could not charge up to the required voltage within the expected timeframe, often due to a low supply voltage or a damaged pre-charge resistor.
The power unit DC link was not able to be pre-charged within the expected time.
  • There is no line supply voltage connected.
  • The line contactor/line side switch has not been closed.
  • The line supply voltage is too low.
  • The pre-charging resistors are overheated as there were too many pre-charging operations per time unit.
  • The pre-charging resistors are overheated as the DC link capacitance is too high.
  • The pre-charging resistors are overheated.
  • The pre-charging resistors are overheated as the line contactor was closed during the DC link fast discharge through the Braking Module.
  • The DC link has either a ground fault or a short-circuit.
  • The pre-charging circuit is possibly defective.
Check the line supply voltage at the input terminals.
