F30050 fault in siemens sinamics V90 drive
F30050 fault in siemens sinamics V90 drive indicates a 24 V supply overvoltage. This means the external 24V DC control power connected to the drive has spiked above safe hardware limits.
The voltage monitor signals an overvoltage fault on the module.
  • Check the 24 V power supply.
  • Replace the module if necessary.
