F31130 fault in siemens sinamics V90 drive
F31130 fault in siemens sinamics V90 drive indicates a Zero mark and position error from coarse synchronization. This means the encoder’s zero mark was detected outside its expected phase window after initial pole position identification.
After initializing the pole position using track C/D, Hall signals or pole position identification routine, the zero mark was detected outside the permissible range. For distance-coded encoders, the test is carried out after passing 2 zero marks. Fine synchronization was not carried out.
  • Check that the encoder cables are routed in compliance with EMC.
  • Check the plug connections.
  • If the Hall sensor is used as an equivalent for track C/D, check the connection.
  • Check the connection of track C or D.
  • Replace the encoder or encoder cable.
