F31150 fault in siemens sinamics V90 drive indicates an Initialization error. This means the drive could not successfully boot or communicate with the connected encoder upon startup.
Encoder functionality is not operating correctly.
- Check the encoder type used (incremental/absolute) and the encoder cable.
- If relevant, note additional fault messages that describe the fault in detail.
