F52983 fault in siemens sinamics V90 drive
F52983 fault in siemens sinamics V90 drive indicates No encoder detected. This means the drive cannot see an encoder connected to it and this particular servo drive does not support encoderless operation.
The servo drive in use does not support encoderless operation.
  • Check the encoder cable connection between the servo drive and the servo motor.
  • Use a servo motor with encoder.
