F52984 fault in siemens sinamics V90 drive indicates the Incremental encoder motor is not configured. This means the motor failed to complete its initial commissioning and needs its motor ID manually configured.
• Commissioning of the servo motor has failed.
• The incremental encoder motor is connected but fails to commission.
- Configure the motor ID by setting the parameter p29000.
