F7453 fault in siemens sinamics V90 drive indicates a Position actual value preprocessing error. This means the drive failed to process the incoming encoder position data, pointing to an encoder signal or hardware issue.
An error has occurred during the position actual value preprocessing.
Check the encoder for the position actual value preprocessing.
