F7458 fault in siemens sinamics V90 drive indicates the EPOS Reference cam was not found. This means the axis traveled its maximum allowed distance during a homing routine without ever triggering the home position switch (reference cam).
After starting the search for reference, the axis moved through the maximum permissible distance to search for the reference cam without actually finding the reference cam.
- Check the “reference cam” input.
- Check the maximum permissible distance to the reference cam (p2606).
See also: p2606 (EPOS search for reference cam maximum distance)
