F7459 fault in siemens sinamics V90 drive
F7459 fault in siemens sinamics V90 drive indicates a Zero mark was not detected. This means the axis passed the reference switch but failed to find the encoder’s physical zero mark pulse within the expected distance.
After leaving the reference cam, the axis has traversed the maximum permissible distance (p2609) between the reference cam and the zero mark without finding the zero mark.
  • Check the encoder regarding zero mark.
  • Check the maximum permissible distance between the reference cam and zero mark (p2609).
  • Use an external encoder zero mark (equivalent zero mark).
