A5013 alarm in ABB ACS150
How can resolve problem A5013 alarm in ABB ACS150 ?
Cause : Panel control is disabled because start inhibit is active.
1. Start from the panel is not possible.
2. Reset the emergency stop command or remove the 3-wire stop command before starting from the panel.
Cause : Button is disabled, because start is inhibited.
set parameter
2108 - 0 (Disables the Start inhibit function.)
1601 - 0 (Disable run enable)
2109 - 0
Sets the Start inhibit function on or off.
If the drive is not actively started and running, the Start inhibit function ignores a pending start command in any of the following situations and a new start command is required.
A fault is reset.
Run Enable (parameter 1601) activates while start command is active.
Mode changes from local to remote.
Control switches from EXT1 to EXT2.
Control switches from EXT2 to EXT1
