ABB ACS355 Drive Programming
Optimize your ABB ACS355 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB ACS355 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of ACS355 drive.
acs355 abb standard wiring image 1
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Below image show power wiring of ACS355 drive.
abb acs355 drive power wiring image 4
Step 3 – Parameters
Below list show all parameter used in ACS355 drive programming.
Motor Data
Application Macro 9902 1 ABB Standard
Motor Voltage 9905 ……V Voltage
Motor Current 9906 ……A Ampere
Motor Frequency 9907 ……Hz Freq
Motor Speed 9908 ……rpm Speed
Motor Power 9909 ……KW Power
Limits
Minimum Speed 2001 ……rpm rpm
Maximum Speed 2002 ……rpm rpm
Minimum frequency 2007 ……Hz Hz
Maximum frequency 2008 ……Hz Hz
ACC Time 2202 ……s s
DEC Time 2203 ……s s
Ref minimum 1104 …… Hz/rpm
Ref Maximum 1105 …… Hz/rpm
Step 4 – Testing and Verification
  1. Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
  2. Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings
