2340 SHORT CIRCUIT Fault in ABB ACS800 Drive
5 Users
1 Reactions
16.3 K Views
How can resolve problem 2340 SHORT CIRCUIT Fault in ABB ACS800 Drive ?
Cause : Short-circuit in motor cable(s) or motor.
Check motor and motor cable.
Check there are no power factor correction
capacitors or surge absorbers in motor cable.
(@jromerov)
New Member
@click2electro
Hello there. Any other cause for this fault to occur?
Condition of fault coming continuously or coming after run command ?
(@bharatburbure)
New Member
If motor and motor cable found OK, then it was hardware fault, surely.
@bharatburbure yes it is an hardware fault.
(@tahir)
Active Member
It can be a fault due to shorted IGBT as well.
@tahir
This fault comes when IGBT faulty, Motor Faulty, CT Faulty and faulty motor connetion
 jose
(@jose)
New Member
@tahir hey how did you resolve this issue please we disconnected the motor cables and the short sircuit fault is still showing 2340
@jose after remove motor cable if fault still coming then IGBT, ZINT board or CT faulty.
