Check Connection Fault on ACS880 Drive
4 Users
1 Reactions
(@berkayd)
New Member
Dear All,
          This is my first message in this forum, and I'm in need of some help from experts on this matter. For a marine vessel, Auxiliary Boiler Fans are equipped with ACS 880 Drives (2 drives, 1 for each fan). Just 2 days ago, suddenly both VFDs started to show the attached screen, and pressing the Start/Stop or Loc/Rem buttons does not have any effect; nothing changes on the screen. I would appreciate any suggestions and recommendations from experts. The controller is connected via LAN cable to the drive, for your information.
First remove display and reinsert properly.
If you have another display and then check with that.
(@bapun20)
New Member
How to clear this troubleshooting
@bapun20 check with another display and also replace display cable and then check.
(@pritish-chandra-santra-3949)
New Member
@click2electro check another display and cable but same problem,this display connected another drive and check then working properly.
@pritish-chandra-santra-3949 try to change cable also if problem same then problem related to the control card
New Member
@click2electro ok but VFD on and also motor run to local push bottom start.
@pritish-chandra-santra-3949 please share a video also
May be display cable problem.
