fault 2330 earth leakage - comes when drive has detected load unbalance typically due to earth fault in motor or motor cable, faulty drive earthing, faulty motor & motor cable or faulty IGBT of drive.
Cause : Drive has detected load unbalance typically due to earth fault in motor or motor cable. Check drive earthing. Check motor & motor cable. Check drive IGBT using multi-meter.
Solution for fault 2330 earth leakage in abb drives,
Solution for ABB ACS880 Drive
Click here for 2330 Earth leakage Fault in ABB ACS880 Drive
Solution for ABB ACS380 Drive
Click here for 2330 Earth leakage Fault in ABB ACS380 Drive
Solution For ABB ACS580 Drive
Click here for 2330 Earth leakage Fault in ABB ACS580 Drive
Â
Â
Â
