ff61 abb fault - comes when motor ID run was not completed successfully. Check motor parameter & tune again. If fault coming after then reset drive to factory reset & enter motor data again then tune again.
Cause : Motor ID run was not completed successfully. Check motor parameter & tune again. If fault coming after then reset drive to factory reset & enter motor data again then tune again.
For ABB ACS880
Click here FF61 ID run Fault in ABB ACS880 Drive
For ABB ACS380
Click here FF61 ID run Fault in ABB ACS380 Drive
For ABB ACS580
Click here FF61 ID run Fault in ABB ACS580 Drive
For ABB ACS560
Click here FF61 ID run Fault in ABB ACS560 Drive
