How do you reset th...
How do you reset the fault on ABB drive?
If fault coming in ABB drive then press stop button and check fault code, confirm with manual - like programmable fault or hardware failure fault coming.
To reset the drive for faults indicated by a red LED on display (on, not flashing), check fault code if fault is programmable then check parameter and reset fault, correct the problem and do one of the following: From the control panel, press RESET Turn off the power for 5 minutes.
