How can resolve problem oH2 warning in delta C200 series drive ?
Cause : Capacity over-heating warning.
The drive has detected the key components are overheat.
1. Check the ambient temperature.
2. Regularly inspect the ventilation hole of the control cabinet.
3. Change the installed place if there are heating objects, such as braking
resistors, in the surroundings.
4. Install / add cooling fan or air conditioner to lower the temperature inside the
cabinet.
Check if the drive matches the corresponded loading
1. Decrease loading.
2. Decrease the carrier.
3. Replace with a drive with larger capacity
