LiT fault in delta C2000 series drive
How can resolve problem LiT fault in delta C2000 series drive ?
Limit Error (LiT)
This code occurs when the motor drive is running under speed mode (not IMFOCPG / PMFOCPG), and the negative running limit or the positive running limit of the MI terminals is enabled.
Action conidition - When under the speed mode (not FOCPG), negative running limit or positive running limit is enabled.
Move the motor away from the limit position, press the STOP / RESET button on the keypad (manual reset).
The limit ON / OFF switch may be on the wrong position - Install the limit ON/OFF switch to correct position.
