SE1 warning in delta C2000 series drive
How can resolve problem SE1 warning in delta C2000 series drive ?
Save error 1
Keypad COPY error 1: Keypad copy time-out
“SE1” warning occurs when the keypad does not transmit the COPY command
to the drive, and does not transmit any data to the drive again in 10 ms at the
time you copy the parameters to the drive.
SE1: The causes of error are mostly communication problems between the
keypad and control board. Potential causes include communication signal
interference and the unacceptable communication command to the Slave.
Check if the error occurs randomly, or only occurs when copying certain
parameters
