CE1 fault in delta ...
CE1 fault in delta drive
Cause : Illegal command comes when incorrect communication command from upper unit or malfunction caused by interference. The drive resets automatically when receiving the correct function code.
The CE1 fault in delta drive indicates an Illegal command. This means the drive received a command that it doesn't understand or can't execute.
  1. Check if the communication command is correct.
  2. Check the cable and replace it if necessary.
