Delta Drives
255
Jun 24, 2024 9:12 am
Cause : Motor overheating comes when the drive has detected that the motor temperature has exceeded a safe operating limit.
The oH3 fault in Delta drive indicates a Motor overheating condition. This means the drive has detected that the motor temperature has exceeded a safe operating limit.
- Reduce the load.
- Increase the motor capacity.
- Check the cooling system to make it work normally.
- Increase the setting values (accel./decel. time).
- Reset to the correct motor rated current.
