ot3 fault in delta ...
ot3 fault in delta drive
Cause : Over-torque 3 comes when the output current exceeds the over-torque detection level and exceeds over-torque detection time then this fault displays.
The fault ot3 in Delta drive indicates an over-torque 3 fault. This means the motor connected to the drive has exceeded its set torque limit for a certain period.
  1. Reduce the load.
  2. Replace the motor with a larger capacity model.
  3. Increase the setting for - accel./ decel. time.
  4. Adjust the torque compensation
