Delta MS300 Series Drive
289
Jun 22, 2024 8:50 am
Cause :Â Illegal command comes when incorrect communication command from upper unit or malfunction caused by interference. This fault occurs when Pr.09-02=0 and the motor drive keeps running. The drive resets automatically when receiving the correct function code.
The code CE1 indicates an Illegal command fault with your Delta MS300 drive. This means the drive received a command that it doesn't understand or can't execute.
- Check if the communication command is correct.
- Check if the setting for Pr.09-02 is the same as the setting for the upper unit.
- Check the cable and replace it if necessary.
